Welcome to autemo!
It appears you've found the right section to begin with
And now onto the chop:
There's lots of good on this - the new front end looks great, fits perfectly and gives the car a far more aggressive look
The rims also fit really well, and match the style perfectly
The only thing that bothers me really is the backdrop - the perspective doesn't quite match up with that of the car, and neither does the lighting - if you look at the car's reflections, it has lots of bright ones high up, suggesting it's not in an enclosed space, much like the base, however on the backdrop, there are clearly a lot of trees overhead that would be reflected in the car's body work, and make it look darker overall
Other than that good stuff - you should post some of your other work up
